  2. Licensing and Installation
  3. Any guide on upgrading Cadence Allegro from 17.2 to 23....
  • State Verified Answer
  • Subscribers 7
  • Views 6660
Any guide on upgrading Cadence Allegro from 17.2 to 23.1
Ron8778
Ron8778 over 2 years ago
Hi all,
Is there any guide for upgrading Cadence Allegro from 17.2 to 23.1?
  • JuanCR
    JuanCR over 2 years ago +2 verified
    Hi Ron8778, All the licensing information you can find in the following link: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O0V000007MmzEUAS&pageName=ArticleContent&sq=005d0000001T5WTAA0…
  • Ron8778
    Ron8778 over 2 years ago in reply to JuanCR +1
    Thanks for the reply. All I need is just install the download manager, and everything will be installed accordingly?
  • JuanCR
    +1 JuanCR over 2 years ago
    Hi Ron8778,
    But if you're looking for an easy way to install 23.1, I'd advise you go to https://downloads.cadence.com/ESDWeb/Welcome.eo and get the Download Manager. See this screenshot:
    Once you install the download manager, getting any version of the software you have a license for is very easy. Simply find the software in the list and click on the dropdown menu to select the version. If you're interested in 23.1, it will look like this:
    Finally, click on "Install" to install the software or "Update" to download a new hotfix available.
    Let me know if you have further questions.
    • Vote Up +2 Vote Down
  • Ron8778
    0 Ron8778 over 2 years ago in reply to JuanCR
  • JuanCR
    0 JuanCR over 2 years ago in reply to Ron8778
    It won't be installed automatically. You do need to select the version of the software that you want and click on "Install". So it is a manual process, but it is significantly easier than any other method.
  • Ron8778
    Thanks for the info JuanCR  I will setup a test environment to test it out to upgrade from 17.2 to latest version.
