  2. Licensing and Installation
  3. Installation and Uninstallation commands for PCB Editor...
  • Replies 12
  • Subscribers 7
  • Views 11843
Installation and Uninstallation commands for PCB Editor Viewer
FN202508065815
FN202508065815 over 1 year ago
I am looking for installation and uninstallation commands for PCB Editor Viewer. We are trying to make this software available via Microsoft Intune.
  • Prabal
    Prabal over 1 year ago +1
    Download the CadencePCBViewers.exe installer from the following location: www.cadence.com/.../allegro-downloads-start.html After downloading the installer, follow these steps: 1. Move the CadencePCBViewers…
  • FN202508065815
    FN202508065815 over 1 year ago in reply to Prabal +1
    Thank you ! The remove command does not work, instead of removing it reinstalls the application back again. Any suggestions please ?
  • Prabal
    Prabal over 1 year ago in reply to FN202508065815 +1
    Thank you, let me check and get back to you. So, to be clear this command did not work: c:\cadence\CadencePCBViewers.exe -remove
  • Prabal
    0 Prabal over 1 year ago
    1. Move the CadencePCBViewers.exe to a directory. In this case CadencePCBViewers.exe was moved to C:\Cadence directory.
    2. Open Windows Command Prompt from the location of the installer.
    3. Enter the following command to start the silent installation:
    CadencePCBViewers.exe -silent -TARGETDIR=<Installation directory>
    For example: c:\cadence\CadencePCBViewers.exe -silent -TARGETDIR=c:\cadence\CadencePCBViewerInstall
    Note: If you have the SPB23.1 software installed, the silent installation of Allegro Free Physical Viewer will not proceed.
    To Silently uninstall enter the follow command:
    For example: c:\cadence\CadencePCBViewers.exe -remove
  • FN202508065815
    0 FN202508065815 over 1 year ago in reply to Prabal
    Thank you !
  • Prabal
    0 Prabal over 1 year ago in reply to FN202508065815
  • FN202508065815
    Correct, this is not working for uninstallation c:\cadence\CadencePCBViewers.exe -remove
    When you run this command, it actually re-installed the application again.
    Waiting for your inputs, Thank you
  • Prabal
    Thank you so much for bringing this issue to our attention. I concur that it is indeed not honoring the -remove argument and starts to re-install again. I will take this to the internal team and let you know if I get any update.
    Thank you!
