  2. Licensing and Installation
  3. Cadence PCB Viewer silent install commands
  • Subscribers 7
  • Views 3098
JA202509165115
JA202509165115 over 1 year ago
Hi there,
looking to deploy PCB Viewer via Intune. The installation command im using to install when testing locally is "CadencePCBViewers.exe -silent", the uninstall command i'm using is CadencePCBViewers.exe -remove.
These both work when running locally however it fails to install when deploying it via Intune.
Would you be able to provide me assistance please?
  • Prabal
    0 Prabal over 1 year ago
    I have not used intune. Can you give me all the messages that you get while trying to work on Intune. Cadence does not support intune so there is no way to test it.
  • JA202509165115
    0 JA202509165115 over 1 year ago in reply to Prabal
    Hi there,
    The error i get is:
    The file name - *C:\windows\system32\config\systemprofile\AppData\Roaming\Cadence\PCBViewerinstall\silentinstall-FV.ini" was not found. Aborting the installation.
    I believe the issue is that the app is looking for temp files which would only appear in the appdata directory for the local user when running as admin whereas when deployed via intune the installation is ran in the system context and as such would not copy any files to the users app data directory.
