  3. Allegro Design Entry Part table file conumdrum.
  • Views 14684
Mike Veal
Mike Veal over 17 years ago
Hi All,
I have a poser for you. IBM stipulate that I must work with a corporate library.
The part table file for this corporate leviathan is built automatically on a daily basis. Any changes I make to the ptf would therefore be overwritten and lost.
However, change is exaclty what I need. The corporate ptf does not contain SIGNAL_MODEL properties. I wish to embed these models into my designs at the ptf level. I am aware that these models can also be assigned at either the schematic or in the board file, but I have found that placing the model in the part table file is the quickest and cleanest method of working. It also has advantages when integrating the PI tool into a design flow.
 Is there any way that Packager XL can be instructed to merge data in different ptf's?
For example:
Corporate ptf:
PART_NUMBER = PART_NUMBER, FOOTPRINT, etc.
FRED                 = FRED,                0805,            etc
BERT                 = BERT,                0603,             etc
JOHN                 = JOHN,                0402,             et
local.ptf:
PART_NUMBER = SIGNAL_MODEL
FRED                 = MODEL_FRED
BERT                 = MODEL_BERT
What I want Packager XL to do is to look through both the corporate.ptf and the local.ptf files.
When packaging part_number BERT, packager XL would pass to the board file:
           PART_NUMBER=BERT, FOOTPRINT=0603, SIGNAL_MODEL=MODEL_BERT, etc.
   similarly, when packaging part number  FRED, PackagerXL would pass :
           PART_NUMBER=FRED, FOOTPRINT=0805, SIGNAL_MODEL=MODEL_FRED, etc.
  but when packaging part number JOHN, then Packager XL would pass:
           PART_NUMBER=JOHN, FOOTPRINT=0402, etc
(since JOHN doesn't have a entry in the local.ptf).
So is there a method of changing PackagerXL's behaviour to act like this. If I remember correctly, it normally just fails if it finds two part table file lines with the same values onthe left of the =.
Or, alternatively, does anyone have another method of achieving this?
Mike Veal.
  • jhorner
    jhorner over 17 years ago
    There is a Merge Physical Part Table Files check button in the Part Table setup from Project manager.
    This should do what you are looking for.
