  3. Xnet
  • Subscribers 167
  • Views 14439
Xnet
kumar
kumar over 17 years ago
Hi All,
Can any tell me how to creat an xnet?
Kumar
  • jhorner
    jhorner over 17 years ago
    Xnets will be created automatically when you assign signal models to any series resistors/capacitors.
    Use the Setup Advisor from Allegro and under the Device Setup you are given the option to greate models for these 2 pin components.
    From Concept, use the Model Assignment dialog to create/assign these models.
  • Ejlersen
    Ejlersen over 17 years ago
    Remember that if you're using Allegro PCB Performance option and not PCB XL/GXL then you will need to run Tools, Database check in order for the PCB Editor to register the xnet correctly.
  • Community Operations
    Community Operations over 17 years ago
    THIS IS ONLY A TEST
    Sorry for any inconvenienece to users.
    Checking out an email subscription issue.
    communityops
  • mvonahnen
    mvonahnen over 17 years ago
     What is the command sequence in Allegro PCB Editior to do this?
  • mvonahnen
    Setting up the component models I mean,
