  3. Error of allegro
  • Subscribers 163
  • Views 17156
Error of allegro
archive over 17 years ago
Dear all,
The screen shots shows the error i have faced. Do anyone know how and why it occurs? When i faced this error, i must restart the tool to cancel it and/or it will turned off. I will lose my unsaved work. Can anyone explain this?
Thanks and Regards,
Shiva.
    As I've mentioned in another thread, here's what I do when it crashes (it does save your work, just as a .SAV file)
    1) Rename the current .brd file, just in case
    2) Open allegro
    3) Type shell (cr = carriage return)
    4) Type dbdoctor
    This will take your last saved .SAV file, fix it, and save it as a .brd file
    Open it in Allegro and continue on.
    Good day.
    Mitch
  • BillZ
    BillZ over 17 years ago
    Can you verify the ISR level you are at? Go to Help>About
    The current release is 16.01 S030 dated 7/23/2008. If you have a P00X number you are running the base release. You should obtain the latest ISR from Sourcelink.
    Also try disabeling the OpenGL in Setup>User Preferences. If the crashes stop I would suggest getting the latest drivers for your video card.
    Just some of the things you can try.
    BillZ
    EMA Design Automation
