  3. addition of components
  • Subscribers 167
  • Views 13175
purikku22
purikku22 over 17 years ago
we had finished a design and after the power simulation, the customer wanted to add some demitas capacitors. the customer only provided the new netlist ( which includes the new nets). how can i add the components on the board? i tried the copy (symbol) but i cannot add refdes to the components (it says that refdes is not available). what will i do to add refdes? I cannot do a successful Net import without assigning the new components first.im using Allegro PCB Perfomance Option L 15.7. what should i do?
 regards,
eric
  • edhickey
    edhickey over 17 years ago
    Try adding the components from the menu path
    Logic - Part Logic
    In the main section of the form, select the device you want to copy then backspace the current Ref Des List and add a string of new caps (ex C100-150)
  • purikku22
    edhickey thanks. i successfully added the capacitors. but my problem now is the net import. the capacitors are declared already in the netlist, but after importing the cpacitors dont still possess the net. what could be the problem now? eg. C270 (this is the net file)
    $PACKAGES
    ! ACK747__101P050 ; C254 C256 C258 C260 C263 C265 C266 C267 ,
            C270 C272 C273 C274
    $NETS
     P12D ; BD93.2 BD94.2 BD95.2 C1004.2 C1009.2,
            C12.1 C13.1 C16.1 C19.1 C23.1,
            C26.2 C27.2 C270.1 C271.1 C272.1,
            C273.1 C274.1 C275.1 C69.1 C886.1,
            C887.1 IC1.14 IC1.2 IC1.6 IC16.4,
            IC16.5 IC17.4 IC17.5 IC2.A11 IC2.A13,
            IC2.A3 IC2.A5 IC2.A7 IC2.A9 IC2.B1,
            IC2.C10 IC2.C12 IC2.C14 IC2.D1 IC2.E10,
            IC2.E12 IC2.E14 IC2.F1 IC3.14 IC3.2,
            IC3.6 IC5.10 IC5.11 IC5.9 L1.2,
            R28.2 R699.1
     LG;
            C262.2 C263.2 C265.2 C266.2 C267.2,
            C268.2 C269.2 C27.1 C270.2 C271.2,
            C272.2 C273.2 C274.2 C275.2 C28.1,
  • navigator
    navigator over 17 years ago
    Ed .. just tried this one .. WOW … is that ever sweet how that works ….
    Vincent Di Lello
