  3. Capture to Allegro Error(15.7 PCB Editor L)
  • Views 660
Ragesh
Ragesh over 17 years ago
While updating the board , i am facing the following error.
Please post your suggestions to resolve this problem.
netrev
" Program has encountered a problem and must exit.The database will be saved(if applicable).Obtain the latest software update from Cadence and if problem persists contact Cadence Customer Support "
Ragesh
  • oldmouldy
    oldmouldy over 17 years ago
    You probably need to obtain the last hotfix issued for 15.7.
    Since you are still using 15.7, that might suggest that you are no longer in maintenance and unable to obtain hotfixes through SourceLiink.
