  3. Dimensioning
  • Subscribers 163
  • Views 13325
Dimensioning
budnoel
budnoel over 17 years ago
Can someone direct me to a good tutorial on dimensioning in PCB Editor?  I am struggling attempting to achieve my desired dimensions.
  • mcatramb91
    mcatramb91 over 17 years ago
    Over the years the help documentation has changed/reformated slightly but the information is all there.  The Drafting and Dimensioning module has not changed in sometime and I found an old PDF file which goes thru the steps on adding dimension features in Allegro which may be of some use to you.  See attached PDF.
    Hope this helps,
    Michael Catrambone
    UTStarcom, Inc.
    Allegro_Draft_n_Dims_help.pdf
  • mcatramb91
    Hope this helps,
    Michael Catrambone
    UTStarcom, Inc.
