  3. "Undefined Line Width" default to Zero in Film Record -...
  • Views 6021
"Undefined Line Width" default to Zero in Film Record - Gerber still outputs without Error
mcatramb91
mcatramb91 over 17 years ago
I just noticed something that I thought was a little strange.  I added an additional Artwork Film Record for a special fabrication drawing and forgot to modify the "Undefined Line Width" inside of the Film Record.  When I output the gerber it only reported warnings in the log file and not an error due to the missing aperture for the "0" Line.  Part of my post processing script is to generate PDF File of some of the output Gerber Files and to my surprise most of the data was missing from this one PDF file which is because there was not an aperture with a line width of "0" so it did not draw anything in the Gerber.  The message in the Photoplot.log was as follows:
WARNING: 0 width  line found at (559.250 8280.710)
         ... ignored!
Multiple 0 width  lines; all will be treated the same as the first.
Either way I figured I would post this to let folks know that may not be aware of it.  No sure if it would be considered a software bug because I guess I should be more careful and reviewed all the log files.  Wasn't a major deal for me because it was caught upon review of the PDF files that were generated in error.  All my artwork film records are normally generated by script which defines the line width so this was an isolated where I generated a new film record manually and forgot to change the "Undefined Line Width"
Mike Catrambone
UTStarcom, Inc.
    archive over 17 years ago
    Mike,
    This is a good point. I also had experienced the same problem earlier and corrected it by setting the "Undefined Line Width" to the required valuer in film options. By the way, I would like to know how to create the artwork using scripts. I don't have much experience in scripting. It will be helpful if you can share a basic/example artwork script or direct me to how to create a script.
    Thanks in advance
    Babu
  • Rajiv Vig
    Rajiv Vig over 17 years ago
    While generating gerber data, I am using 0.1mm as undefined line width for all the layers being used for Gerber generation &  it works.
  • DTSE
    DTSE over 17 years ago
    Without scripting you can use the "save all checked" once all your artworks have been created within the Artwork Control Form, this will generate a setup file named "FILM_SETUP.txt " which you can edit if necessary and reuse elsewhere, hope it helps.
    Yes. This is easier than a script. Really helpful.
    Thanks a lot,
    Babu
  • mcatramb91
    Sorry for my slow response.  Trying to finish up work and get ready for CDNLive! Silicon Valley.
    My script does much more than just add film records it adds custom title blocks, basic fabrication drawing stackup, etc. I have been slowly moving it into more of a SKILL based script but most of it is still ran inside of UNIX using small NAWK scripts with an UNIX Script front end.
    I did present a paper some time ago which is still relevant in a lot of sections and it may be helpful so you could see exactly what I do.
    I will start another thread on this topic. "Automating Artwork Film Record and Title Block Generation"
    Hope this helps,
    Mike Catrambone
    UTStarcom, Inc.
