  3. Issue with Allegro PCB
  • Views 14436
mvonahnen
mvonahnen over 17 years ago
 I get the following error when I try to do an update symbol command:
refresh_symbol
Program has encountered a problem and must exit.  The database will be saved (if applicable).  Obtain the latest software from Cadence and if the problem persists contact Cadence Customer Support.
 I thought it was because some of my components were "fixed", but I have restarted the program and tried it again.  I tried it with all my components and with just one, and I get the same error.
 I think I have the latest version (16.1 p004 (v16-1-53D)
  • Khurana
    Khurana over 17 years ago
    Go to Tools > Database check > click Check button > File > Save.  Type reopen in command line to reopen the design.  Now try update symbols.
  • purikku22
    purikku22 over 17 years ago
    also try checking your padstack path locations. i also  once encountered this error and i just miss to include my current padstack path in the enved settings.
  • BillZ
    BillZ over 17 years ago
    Hi
    I would highly recommend you download the latest hotfix from Sourcelink.
    You are running the base release. The latest hot fix is dated August 25 2008.
    BillZ
    EMA Design Automation
