  3. Newbie on PCB Editor
  • Replies 23
  • Subscribers 168
  • Views 26261
sympatique
sympatique over 17 years ago
Hello everyboby !!!
I am newbie on PCB editor , I have make my shematic with Orcad Capture CIS, And I really don't know where to retrive the
information on how to transfer my shematic on the PCB Editor.  I have made the cross reference report, design rules check, and
the netlist...
I work with version 16.0
Thank you for reading my mesage.
Thank you for your help.
  • sympatique
    Ok. No more warnings or errors.
    But i can't open the bord in Orcad PCB Editor..
    I receive a warning windows message
    ORCAD PCB DEMO
    ! (WARNING (SDMHOD-33):
    Database was last saved by a higher tier tool... Allegro Expert.  There may be constraint ruless and other design data that may be
    ignore in this tools.
    Can i go farthest with this demo ??
  • tltoth
    tltoth over 17 years ago
    Of course you can. First draw your board outline then place your components and route your board.
    There is an excellent tutorial on it. <install_dir>\doc\flowtut\flowtut.pdf     Chapter 5  Board design using OrCAD PCB Editor
  • sympatique
    The tutorial is fine...
    I success my Artwork, and it is in color on the screen.  When I print it, the printout is in gray scale on my monochrome laser.  Is it possible to get black printout for a good PCB process.
    Thank you.
  • tltoth
     How did you made your printout?.  Have you printed it from PCB Editor or from some Gerber Editor/Viewer?
  • sympatique
    I made the printout from PCB editor    File --> import -->  Artwork.
    I Have download a free Gerber Viewer from Protel and the result is perfect.
    Thank you Again for your help.
