  3. Orcad Capture 10.0 Library Question
  • Views 15217
OregonGuy
OregonGuy over 17 years ago
I'm using an older version of Orcad Capture.  Somehow I lost the library with all the new parts I created.
Is there a way to generate a new library from the design cache parts?
  • redwire
    redwire over 17 years ago
     Deleted -- see next post for suggestion.
  • oldmouldy
    oldmouldy over 17 years ago
    Open the Project
    File>New>Library
    This will create a library<n>.olb, in the project window, right-click>Save As, to save the file with a known name and location.
    Open up the Design Cache, left-click on the first item in the Design Cache and shift+left-click on the last item to select the contents of the Design Cache. Control+C to Copy, left-click on the new library name and Control+V to Paste. Right-Click>Save on the library name to save the library.
    Afterwards the library contents can be edited, as in the globals and off-page & hierarchical contents can be removed.
  • OregonGuy
    dragging the cache parts to a new library seemed to work.
  • redwire
     Dang that's cool!  Never knew that one!  Will have to try it.
    (note: just tried it. Saved me some hassles!)
    Bill
  • Ejlersen
    Ejlersen over 17 years ago
    When you're copying from the design cache, look out for _0, _1 etc parts. They occur if someone has edited the part from within the Capture design. You'll probably end up with a number of different graphical representations for the same component.
    Actually the easiest procedure for creating your own library is to open an existing library and your own. Select the parts you want and use drag and drop to copy from one library to the other.
