  3. CADIF/Neutral File Format
  • Views 2981
delb
delb over 17 years ago
Is there any way to get an equivalent of a CADIF netral file format output of an Allegro PCB design?
  • steve
    steve over 17 years ago
    At a previous company we used to have a "bolt on" piece of software called OHIO Harmony that had a GENCAD (cadif neutral file) export. I believe that this company was bought out by PTC so not sure whether you can still get your hands on it.
    Cheers
    Steve
  • Charlie Davies
    Charlie Davies over 17 years ago
    The only export to CADIF from Allegro that I'm aware of, is from the old OHIO folks.  They had a translator that used extract files as the source data and created a "paf" file.  This was all done in support of getting the Allegro design into their InterComm product.  They have altered that interface several times over the years and I believe they have abandoned that methodolgy in favor of another approach.  The OHIO company was acquired by PTC.  You would need to contact PTC to see if there is still a capability available.
    Good luck.
