  3. PDF Plot with searchable text
  • Views 15780
bulldog
bulldog over 17 years ago
Does anyone know if it is possible to plot to PDF and have searchable text in the file?
If so please let me know how!
  • Javinder
    Javinder over 17 years ago
     Yes, you can plot an PDF file with searchable text from Allegro PCB Designer.
     You need some kind if PDF printer installed. I recomend Adobe PDF Distiller or Writer.
    Then you need to open the Allegro Plot setup (File --> Plot Setup), select the Windows tab and check the Vectorized Font box. The fill in desired font.
    When you print select the PDF printer and you should  be able to schearch inyour PDF.
  • bulldog
    Thanks for the input.  This is exactly what I was looking for and it works!
