  3. Wildcards in PCB Editor Paths
  • Views 13904
arcwilson
arcwilson over 17 years ago
 Does anybody know if its possible to define paths in PCB Editor that include wildcards?
 For example, defining the symbol path as <path>/pcb/symbols/*
 I'm trying to get the editor to recognize subdirectories in my local "symbols" directory without having to keep adding additional paths to in the User Preference.  I can't find any information on wildcards, so if anybody knows of a good place to look, it would be appreciated.
  • mcatramb91
    mcatramb91 over 17 years ago
    Actually this works on Solaris but not on Windows.  I believe it is a Windows limitation and not one on Allegro PCB Editor.
    Example:
    On Solaris we have a padstack library broken down into sub-folders as follows:
                <Library Path>/Padstacks/Plated
                <Library Path>/Padstacks/Non-Plated
                <Library Path>/Padstacks/SMD
                <Library Path>/Padstacks/Pin-and-Paste
    Each directory above contains padstack files (*.pad) and in our environment we define the PADPATH as follows:
                PADPATH = <Library Path>/Padstacks/*
    With this setting Allegro will look thru all sub-folders to locate padstacks but unfortunately it only works on Solaris.  Maybe there is an equivalent wildcard character on Windows but I have never found it.
    Hope this helps,
    Michael Catrambone
    UTStarcom, Inc.
  • arcwilson
     That's consistent with what I've been seeing.  I was hoping to do some similar library organization on windows, but it looks like I would have to add those dir paths manually every time we add a new dir... so for now, it seems the hodgepodge library is my only option.  I'm new to the cadence tools, but I'm wondering if there is a way of running script on startup of PCB editor that scans the library tree structure and updates the path file?
  • Javinder
    Javinder over 17 years ago
     Yes, it's possible to run script on startup.
    Just add a file named allegro.ilinit in your pcbenv diractory.
    In this file you can SOURCE script files and also add some skill code if needed.
