  3. Route Priority
  • Views 13823
Route Priority
mvonahnen
mvonahnen over 17 years ago
 I guess I am the only person who has had an issue with this, I don't see this mentioned anywhere I have looked (tutorials, conference papers, or forum).
In the constraint editior
Properties Tab > Net > General Properties
there is a column under Route called "Priority".  I assume the is the preference for which routes get routed first (that might be a big assumption).  But if so, should this be a number and if so, is higher more priority or less priority.
  • mcatramb91
    mcatramb91 over 17 years ago
    There is actually a Net Property called “ROUTE_PRIORITY” and it was truncated to “Priority” under the Route section probably for column width reasons.  Here are the details:
                Net Property: ROUTE_PRIORITY
    Defines a net or group of nets that will need to be a higher priority when auto routing. Use increments of 10 with 1 being the highest.  It is not tied to the DRC system at all and is strictly used to guide the auto router.
    Here is an example which shows that a net or group of nets will have the highest route priority during auto routing.
                            ROUTE_PRIORITY         1
    Hope this helps,
    Michael Catrambone
    UTStarcom, Inc.
  • mcatramb91
                            ROUTE_PRIORITY         1
    Hope this helps,
    Michael Catrambone
    UTStarcom, Inc.
