  3. Library footprints?
  • Replies 7
  • Views 17159
Library footprints?
Rudy
Rudy over 17 years ago
Can someone please recommend the best place/way to search online for package footprints? I'm a new user and I'm trying to avoid making bad footprints while learning the tool.
  • steve
    steve over 17 years ago
    Rudy
    There is a really cool tool out there which is very cheap called PCB Libraries. www.pcblibraries.com. This will supply you with IPC approved footprints. It will also create the Allegro / Orcad footprint direct from the software.
    HTH
    Steve
  • Rudy
    Thanks for the info Steve, looks like a good site.
    Rudy
  • Ejlersen
    Ejlersen over 17 years ago
     You could also look at fpm found at http://www.edaboard.com/ftopic170612.html
    Notice that it requires Allegro PCB Design L + Allegro Performance Option
  • arcwilson
    arcwilson over 17 years ago
     This might sound dumb (I'm brand new to the tool too), but when I finish a footprint I print it out on paper as a sanity check that I didn't screw up the units or make a really dumb mistake.  It won't save you from most small errors, and it probably won't help for leadless packages like BGAs, but its been helpful so far, so I thought I'd share :)
  • Rudy
    Thanks everyone for the comments. It helped me get past the first step. I'm on my way now placing components.
