  3. How to match groups which are having Pin pairs
  • Views 16056
urcuterock
urcuterock over 17 years ago
 I have group of signals and goig for different chips. I aasigned pinpairs in CM but i want to "match group" with in the pin pairs
i mean i want group signas like, signals going to chip1 as group1 and chip2 as group2 and so on...
thanks in advance
  • Khurana
    Khurana over 17 years ago
    Match groups always resolved down to pin pairs (i.e. you may select nets but the matching applies to the pin pairs within the nets you select - this is governed by selecting the "Pin Pairs" option).
    Explicit pin pairs can be defined in the Relative Propagation Delay worksheet, which is used for creating match groups.  To create a pin pair, select a net, right click, select create pin pair, select the two pins from the pop up (you may also create an Electrical Constraint Set by import a topology (.top) file in Constraint Manager and apply the ECSet to the nets, at which point the nets inherit the pin pairs defined in the ECSet).
    To create a match group, multiple select the pin pairs, right click, select create match group.
