  3. DRC ERROR WITH MICRO VIA
  • Views 16463
girish
girish over 17 years ago
what this error means ? Class: DRC ERROR CLASS Subclass: TOP Origin xy: (1345.44 1033.78) Constraint: Minimum Blind/Buried Via Stagger Distance Constraint Set: TEST Constraint Type: PHYSICAL CONSTRAINTS Constraint value: 5 MIL Actual value: 0 MIL
  • redwire
    redwire over 17 years ago
     What version of the tool are you running?
    It sounds like you need to set your bb via spacing to 0 mils.  Historically a SMT pad was considered a bb/via and dropping a via in pad would cause this error.  You could get around it by setting the minimum = 0.  Try that and see if it works.
    Also, post a  JPG of the pad/via with DRC marker to help validate what's going on.
  • girish
    Thanks for the immidiate feedback ,pls. find the attached file.Regards,Girish kumar
  • redwire
     Change your BB Via Stagger Min to 0.0000 (see attachment).  I changed one of my rows to 5.0000 and got the same error as you.  I have to have via in pad (blind via or micro via).
    HTH
