  3. How to mirror the board out line
  • Subscribers 166
  • Views 17648
Prasanna
Prasanna over 17 years ago
Hello all,
 How to mirror the board outline. I have drawn a semi circled, one side flated board outline. I came to know that drawn outline is back view of the bard. all components are going to be placed another side of the baord. If I proceed with same outline , i should consider component side as bottom layer and it will be bit confuse for placement. I would like to mirror the board so that component side wold be on top layer. Just like turning a sheet.
I am using Orcad PCB editor 16.0, how can i get it done without westing time to redraw whole thing. let me know your valuable skills pls.
  • BillZ
    BillZ over 17 years ago
    The easiest way to do this is do an Edit>copy window around the board outline and then RMB(Right Mouse Button) mirror geometry. Pick a new location for the copy and after your done delete the old outline.
    BillZ
    EMA Design Automation
  • Cadpro2K
    Cadpro2K over 17 years ago
    The other, easy way, is the EXPORT TO SUBDRAWING (copy to clipboard), and IMPORT it back in. When you import it, you can mirror the image too.
     Good day
    Mitch
  • mvonahnen
    mvonahnen over 16 years ago
     I don't see where you can mirror on this command, my options allow me only to Rotate the subdrawing.  Can you go through the command sequence that allows you to mirror a Imported subdrawing?
  • Cadpro2K
    Cadpro2K over 16 years ago
    My bad. It doesn't do it on import/subdraing (only rotate).
     You can copy/mirror like was mentioned, or another way is to Manufacture/Dimension/Create Detail; set scale to 1; select the outline; RMB mirror. This will work too.
    Good day. Mitch
