  3. Receiving a device library error netlisting from capture...
  • Views 15552
Receiving a device library error netlisting from capture to PCB editor 16.01
JasonW
JasonW over 17 years ago
 I created two BGA footprints using the PCB editor PCB wizard for a xilinx virtex2p 672FF and a prom for it.  I have a hetergenous part in capture for the 672FF part.  Since the capture part doesn't have every pin instantiated, I added the PINCOUNT = 672 to the 672FF and PINCOUNT = 48 for the prom.
When I try to netlist to allegro I get the following errors
------ Oversights/Warnings/Errors ------
#1 WARNING(SPMHNI-184): Device library warning detected.
WARNING(SPMHUT-72): Pincount for device 'XCF08PFS48_0_BGA48C80P6X8_800X9' is greater than the actual number of pins ... adding NC pins to compensate.
#1 ERROR(SPMHNI-176): Device library error detected.
ERROR(SPMHUT-123): Unable to create the NC pins for 'XCF08PFS48_0_BGA48C80P6X8_800X9' with function pin 'B3': 'ERROR(SPMHUT-111): Alphanumeric pin number found.'.
ERROR(SPMHNI-170): Device 'XCF08PFS48_0_BGA48C80P6X8_800X9' has library errors. Unable to transfer to Allegro.
I've checked the footprints and the capture part, yet I can't find a problem.  Any ideas?
Jason
  • JasonW
    Oops, the above error is just when I tried netlisting the 48 pin BGA not the 672, but the 672 part has the same type of error
  • steve
    steve over 17 years ago
    Jason
    The PINCOUNT property only works with numerical pins. It will not work with A1, A2 etc. You will either have to renumber your BGA or add the NC pins in a comma seperated list for the capture symbol. Be warned though I think that the comma seperated list is limited to 256 characters.
    I would suggest you raising this with Cadence as an enhancement request for PINCOUNT to support BGA pin numbering.
    Steve
  • JasonW
    Thanks for the info Steve!!
    I tried adding a new property called NC_PINS and added the pins to it in the following format (a1, b4, c4, c5, c6) and I addeded a NC_PINS=YES into the allegro.cfg file but when I netlist it kept giving me an error saying the format for NC_PINS is incorrect.  I tried multiple ways, such as without the (), without commas, adding a = and combinations thereof without luck.
    I went ahead and added the NC pins to the symbol, but I would still like to know how to do this right for the future.
    Jason
  • BillZ
    BillZ over 17 years ago
    Here is the procedure to add an NC pin in Capture.
    ·         Add a “NC” property to the part. For the value of the “NC” property, use the pin numbers of the non-electrical pins separated by commas. For example, if you had an 8-pin footprint with the two through-holes being pins 7 and 8, then you would have a 6-pin part on your design with an “NC” property containing the value of 7,8.
