  3. Neck mode
  • Subscribers 163
  • Views 16564
Neck mode
tltoth
tltoth over 17 years ago
Hi. All,
Does the Specctra use "Neck Mode" during routing or can it only be used in interactive routing mode?
  • Ejlersen
    Ejlersen over 17 years ago
    PCB Router (previously know as Specctra) does not use neck mode. If you run a Route, Router Checks inside PCB Editor it will also tell you this.
    PCB Router does have a taper wire function which means that it can decrease line width when it enters into a pad. Inside the PCB Router it is found under the Rules, object type, Clearance and you can set a taper length also.
  • Ejlersen
