  3. how to update changed netlist in design ?
  • Views 16622
Prasanna
Prasanna over 17 years ago
Hi there....
 I am placing components in  board. But there has been some changes made in schematic. component  placement is almost over in my board. Now how should i update changed netlist to my board.?
  • steve
    steve over 17 years ago
    The same way you imported the netlist in the first place. Use File - import - Logic and specify the netlist location.There are some settings to look at but in general the imported netlist will adjust your PCB layout to suit your updated schematic.
    As a rule I always make sure I have a saved copy of the board just in case the schematic changes are not correct.
    Regards
    Steve
