  3. Dielectric Constant of Conductor Copper Layer
  • Replies 9
  • Subscribers 166
  • Views 27479
wERerABbiT
wERerABbiT over 17 years ago
Hi All,
Setup --> Cross Section
The "Layout Cross Section" window allows "Autosolve Mode" to calculate the trace characteristic impedance given all the parameter values ( thickness, dielectric constant, conductivity etc).
May I know the correct value to put for "Dielectic Constant" of a Conductor Copper layer?
Should this value be infinity?
Problem is that when I put a very high value, the impedance goes down to almost zero (which isnt true in practice)
Thanks All
  • Ejlersen
    Ejlersen over 17 years ago
    The best thing to do is to ask your PCB manufacturers for the characteristics of the different materials. You could also go for standard materials and have dielectric constants from that.
  • RFDTeradyne
    RFDTeradyne over 17 years ago
    The value for the dielectric constant on the copper layers in the cross section form is the value of the pre-preg material that flows around the copper traces.  I.e. the dielectric of the parts of the layer that aren't copper.
    Ron Dallas
    Design Technology Group, Teradyne, Inc.
    ph: 978-370-2585
    e-mail: ron.dallas@teradyne.com
  • RFDTeradyne
    I couldn't find this earlier but here is a link to a paper I wrote on stack up settings for CDN Live 2006.  http://www.cdnusers.org/Portals/0/cdnlive/na2006/PNP/PNP_147/147_paper.pdf
    Ron Dallas
    ph: 978-370-2585
  • redwire
    redwire over 17 years ago
     Excellent paper!  It was never clear that that's what was intended.  That change and the hidden trapezoidal setting did wonders.
  • Hossein1357
    Hossein1357 over 11 years ago
    I know it's been a long time since the message posted. However, I am looking for mentioned document and I don't find it. I would really appreciate if you can give me an updated link or send me the document.
     Thanks in advance,
    Hossein
