  3. Error while simulating
  • Replies 14
  • Subscribers 170
  • Views 24352
JETEE
JETEE over 16 years ago
 I am new with ORCAD and its family of products. I was trying to build a Full Adder circuit and the netslist is created fine but when I try to run it using PSpice, i get the following errors:
**** RESUMING TRAN.cir ****
.END
ERROR -- Model Q2N2222 used by Q_Q1 is undefined
ERROR -- Model IO_STM used by U_DSTM1 is undefined
ERROR -- Model IO_STM used by U_DSTM2 is undefined
ERROR -- Model IO_STM used by U_DSTM3 is undefined
ERROR -- Subcircuit 7408 used by X_HD_A1_U1A is undefined
ERROR -- Subcircuit 7408 used by X_HD_A1_U1B is undefined
ERROR -- Subcircuit 7408 used by X_HD_A1_U1C is undefined
ERROR -- Subcircuit 7404 used by X_HD_A1_U2A is undefined
ERROR -- Subcircuit 7404 used by X_HD_A1_U2B is undefined
ERROR -- Subcircuit 7432 used by X_HD_A1_U3A is undefined
ERROR -- Subcircuit 7408 used by X_HD_B1_U1A is undefined
ERROR -- Subcircuit 7408 used by X_HD_B1_U1B is undefined
ERROR -- Subcircuit 7408 used by X_HD_B1_U1C is undefined
ERROR -- Subcircuit 7404 used by X_HD_B1_U2A is undefined
ERROR -- Subcircuit 7404 used by X_HD_B1_U2B is undefined
ERROR -- Subcircuit 7432 used by X_HD_B1_U3A is undefined
ERROR -- Subcircuit 7432 used by X_U1A is undefined
I double checked the path and I cannot figure out the reason on how to fix the errors. Any help is appreciated.
JETEE
  • Khurana
    Khurana over 16 years ago
     The problem is here is that the hierarhical blocks in the Full Adder circuit do not have properties required by PSpice to generate a spice netlist.  The three required properties are PSpiceModel, Implementation, and Implementation Type.  Use the schematics in <install_dir>\tools\pspice\capture_samples folder.
  • Khurana
