  3. Error while simulating
  • Replies 14
  • Subscribers 170
  • Views 24349
JETEE
JETEE over 16 years ago
 I am new with ORCAD and its family of products. I was trying to build a Full Adder circuit and the netslist is created fine but when I try to run it using PSpice, i get the following errors:
**** RESUMING TRAN.cir ****
.END
ERROR -- Model Q2N2222 used by Q_Q1 is undefined
ERROR -- Model IO_STM used by U_DSTM1 is undefined
ERROR -- Model IO_STM used by U_DSTM2 is undefined
ERROR -- Model IO_STM used by U_DSTM3 is undefined
ERROR -- Subcircuit 7408 used by X_HD_A1_U1A is undefined
ERROR -- Subcircuit 7408 used by X_HD_A1_U1B is undefined
ERROR -- Subcircuit 7408 used by X_HD_A1_U1C is undefined
ERROR -- Subcircuit 7404 used by X_HD_A1_U2A is undefined
ERROR -- Subcircuit 7404 used by X_HD_A1_U2B is undefined
ERROR -- Subcircuit 7432 used by X_HD_A1_U3A is undefined
ERROR -- Subcircuit 7408 used by X_HD_B1_U1A is undefined
ERROR -- Subcircuit 7408 used by X_HD_B1_U1B is undefined
ERROR -- Subcircuit 7408 used by X_HD_B1_U1C is undefined
ERROR -- Subcircuit 7404 used by X_HD_B1_U2A is undefined
ERROR -- Subcircuit 7404 used by X_HD_B1_U2B is undefined
ERROR -- Subcircuit 7432 used by X_HD_B1_U3A is undefined
ERROR -- Subcircuit 7432 used by X_U1A is undefined
I double checked the path and I cannot figure out the reason on how to fix the errors. Any help is appreciated.
JETEE
  • hari3132
    hari3132 over 11 years ago
    I am facing the same problem
    I wanna stimulate the transformer model which I developed using magnetic part editor
    I exported the lib file with the capture lib which I have created and it was successful
    But when using it in the circuit I am getting the error as
    **** INCLUDING SCHEMATIC1.net ****
    * source TRANSFORMER
    V_V1         N00191 0  AC 0
    +SIN 0 230 50 0 0 0
    R_R1         N00191 N00195  1 TC=0,0
    R_R2         0 N00270  20000K TC=0,0
    R_R3         N00270 N00281  1k TC=0,0
    X_TX1    N00195 0 N00281 N00270 SCHEMATIC1_TX1
    .subckt SCHEMATIC1_TX1 1 2 3 4
    K_TX1         L1_TX1 L2_TX1 0.99 MYTRANSFORMER
    L1_TX1         1 2 100
    L2_TX1         3 4 100
    .ends SCHEMATIC1_TX1
    **** RESUMING VOLT.cir ****
    .END
    INFO(ORPSIM-15423): Unable to find index file MYTRANSFORMER.ind for library file MYTRANSFORMER.lib.
    INFO(ORPSIM-15422): Making new index file MYTRANSFORMER.ind for library file MYTRANSFORMER.lib.
    Index has 2 entries from 1 file(s).
    ERROR(ORPSIM-15113): Model MYTRANSFORMER used by X_TX1.K_TX1 is undefined
    help me out to solve the problem
  • tltoth
    tltoth over 11 years ago
    You should specify the location of the MYTRANSFORMER.lib in the Edit simulation profile->Configuration Files->Library.
    You can define this library as Global library or add to the current design or just to the current simulation profile.
  • hari3132
    hi thanks for the reply
    i have defined MYTRANSFORMER as global library but still the same error message displayed
    what would be other possible solution for this .
  • Giridharan
    Giridharan over 10 years ago
    **** 08/10/15 17:17:52 ****** PSpice Lite (October 2012) ****** ID# 10813 ****
    ** Profile: "SCHEMATIC1-gg" [ C:\Cadence\Giri project\Metron\6 Parameter\6 parameter-pspicefiles\schematic1\gg.sim ]
    **** CIRCUIT DESCRIPTION
    ** Creating circuit file "gg.cir"
    ** WARNING: THIS AUTOMATICALLY GENERATED FILE MAY BE OVERWRITTEN BY SUBSEQUENT SIMULATIONS
    *Libraries:
    * Profile Libraries :
    * Local Libraries :
    * From [PSPICE NETLIST] section of C:\Users\MURALI\cdssetup\OrCAD_PSpice/16.6.0/PSpice.ini file:
    .lib "nomd.lib"
    *Analysis directives:
    .TRAN 0 1000ns 0
    .OPTIONS ADVCONV
    .PROBE64 V(alias(*)) I(alias(*)) W(alias(*)) D(alias(*)) NOISE(alias(*))
    .INC "..\SCHEMATIC1.net"
    * source 6 PARAMETER
    D_D10 N306500 N306468 D1N4007
    X_LS2 N307038 N305098 N305082 0 N307628 0 N305082 N307644
    + Relay_Dpdt_Bhv_bounce PARAMS:
    + T_make=20m
    + T_break=10m
    + T_bounce=5m
    + I_pull=35ma
    + I_drop=25ma
    + R_coil=100
    + L_coil=5mH
    + R_open=100MEG
    + R_close=.05
    +Contact_match=0.95
    X_X1 N306336 N305674 QZP100K
    X_SW7 N305674 N305874 SW
    V_VAC N306058 N306062 DC 0 AC 230Vac
    R_R12 N306838 N306144 220ohm TC=0,0
    R_R1 0 0 10k TC=0,0
    X_U9 0 N305086 N307380 N305262 N305254 N305246 N305270 N306050 N306066
    + N306074 N306320 N306316 N306324 N306894 LED+ LED-
    X_U6 N306468 N305318 0 SG7805C
    C_C2 0 N305674 33p TC=0,0
    R_R6 N307408 N305146 2k TC=0,0
    R_R11 N305318 N305918 1k TC=0,0
    D_D9 N306108 N306468 D1N4007
    X_SW4 N305674 N305830 SW
    X_MG2 N307456 N307600
    X_U7 N305406 N305098 0 SG7805C
    C_C4 0 N305894 0.1f TC=0,0
    X_U2A N305242 N306838 N305318 0 74LS04 PARAMS:
    + IO_LEVEL=0 MNTYMXDLY=0
    X_SW3 N305674 N305818 SW
    C_C1 N305086 0 10f,16v
    ERROR(ORPSIM-16153): unknown parameter
    C_C6 N305406 0 1000f,16v
    D_D3 N307400 0 LH_3344-TYP
    D_D11 0 N306500 D1N4007
    R_R8 N307400 N305178 2k TC=0,0
    C_C5 0 N305902 0.01f TC=0,0
    X_SW1 N305674 N305706 SW
    D_D8 N307988 0 LH_3344-TYP
    R_R5 N305186 N305318 2k TC=0,0
    X_U1 N305706 N305806 N305818 N305830 N305842 N305470 N305874 N305470 0
    + N305246 N305254 N305262 N305674 N306336 0 N305146 N305162 N305178 N305186
    + N305218 N305230 N305242 0 N305318 N306894 N306324 N306316 N306320 N306074
    + N306066 N306050 N305270 N305086
    R_R10 N307988 N305318 220ohm TC=0,0
    R_R13 N307812 N305918 220ohm TC=0,0
    D_D12 0 N306108 D1N4007
    X_SW5 N305674 N305842 SW
    C_C8 0 N305098 0.1f TC=0,0
    D_D1 N307408 0 LH_3344-TYP
    X_LS1 N305054 N305098 N305082 0 N305078 Relay_Spdt_Bhv_Bounce PARAMS:
    + T_make=20m
    + T_break=10m
    + T_bounce=5m
    + I_pull=35ma
    + I_drop=25ma
    + R_coil=100
    + L_coil=5mH
    + R_open=100MEG
    + R_close=.05
    X_U8 0 N305918 N305078 N305318 N305902 N305894 N305894 N305318
    X_U5 N305098 N307628 N307600 0 0 N307456 N307644 N305098 0 0 0 0 0 0 0
    + N305098
    X_U3A N305230 N307812 VCC 0 74LS04 PARAMS:
    Q_Q1 N305054 N305918 0 BC548A
    D_D6 N307038 N305098 IN4007
    R_R3 N305162 N305318 2K TC=0,0
    R_R7 N307404 N305162 2k TC=0,0
    C_C3 0 N306336 33p TC=0,0
    C_C7 0 N305318 0.1f TC=0,0
    D_D2 N307404 0 LH_3344-TYP
    R_R9 N307412 N305186 2k TC=0,0
    X_SW8 N305674 N305470 SW
    Q_Q2 N307038 N306144 0 BC548A
    X_U4A N305218 N305918 VCC 0 74LS04 PARAMS:
    R_VR1 N305318 0 {10k*0.5+.001}
    R_R2 N305146 N305318 2K TC=0,0
    R_VR2 N305894 N305318 {10k*0.5+.001}
    D_D5 N305054 N305098 IN4007
    X_SW9 N305086 0 SW
    X_SW6 N305674 N305470 SW
    X_TX1 N306058 N306062 N306108 N306500 SCHEMATIC1_TX1
    X_SW2 N305674 N305806 SW
    D_D4 N307412 0 LH_3344-TYP
    R_R4 N305178 N305318 2K TC=0,0
    K_TX1 L1_TX1 L2_TX1 1
    L1_TX1 1 2 10uH
    L2_TX1 3 4 10uH
    **** RESUMING gg.cir ****
    .END
  • tltoth
    tltoth over 10 years ago
    There are two typos in the value field of capacitors C1 and C6.
    Omit the commas after the prefix.
