  3. Changing a desigantion on a global scale
  • Subscribers 166
  • Views 12563
DanHHunter
DanHHunter over 16 years ago
Is there a way to change the reference designation of all the parts in the schematic?
 For example I have a schematic that has R5, R22, R13 only, but I want them to be R1, R2, and R3 without changing each one is there a way to do that?
  • steve
    steve over 16 years ago
    I don't believe there is an easy way..... but if you have a look at the re-package option when using export physical. You can also read Design synchronization and packaging user guide look at the layout tab which gives you options about how HDL numbers parts.
    Regards
    Steve
