  3. How to assign net propety to Jumpers
  • Subscribers 162
  • Views 14970
Prasanna
Prasanna over 17 years ago
Hi all,
I am using Orcad PCB editor 16.0  I need to add two jumper in my board, which is not in schimatic. I have created jumper footprint and loaded to my board. But when i go for Add connect I am not able to assign net property for the pins of jumpers. Can anybody pls tel me how to assign net porperty of other components to jumpers pin ?
Prasanna
  • redwire
    redwire over 17 years ago
     Everything is netlist driven in Allegro so you should fix the schematic or you will break synchronization.  That said, you can do it in Allegro with Logic->Net Logic
  • Prasanna
    thank you redwire,
    I did change in schematic. I am finishing my board. But while setting Ref. designator i found its size is too big. I am no able to place near comp. due to high density. If I make down the size I can fit them in position. Pl s let me know how to change the text size of designator in design.
    regards,
    Prasanna
  • redwire
     There are two ways to change the text size: Edit->Change
    Then set the find filter to Text and in the Options box deselect everything and change the text code to a different code.
    That assumes you have your text table set up properly and just need to change its code.  But if you'd rather change the text table that's done via Setup->Design Parameters, click the Text tab, click the "Setup Text Sizes" button.... play around with that table.
    Obviously you need to know the text code: Display->Element, Find=Text, click on the text ...
    HTH
