  3. Capture CIS error
  • Replies 8
  • Subscribers 166
  • Views 18708
Capture CIS error
laboredm
laboredm over 17 years ago
I'm trying to run a simulation in Capture CIS but the net list is giving me this error
WARNING [NET0093] No PSpiceTemplate for D1, ignoring
WARNING [NET0093] No PSpiceTemplate for D2, ignoring
They are there.  I have been to the pspice model editor and everything seems to be there.  I'm using the one for di.lib.  I need some help.
Thanks.
  • oldmouldy
    oldmouldy over 17 years ago
    Check the Part properties in the schematic, the PSpice Template property for a diode will look "something like":
    D^REFDES %1 %2 @MODEL
    If the property is not there, or blank, that will be the problem. Take a look at the parts in one of the Diode libraries in the installation if you need some examples. If, by some chance, your diode model is a subcircuit rather than a "simple" device model, the PSpice Template property will need to be "something like":
    X^REFDES %1 %2 @MODEL
    If need be, get the Model Editor to make a Capture Symbol and containing library from the model data, using File>Export to Capture Library. This will have the required properties on the generated symbol or log any issues with the library creation.
  • laboredm
    I got the Diode to model thanks.
  • Slayer7
    Slayer7 over 17 years ago
     plZ what about this errors
    "ERROR:  [NET0085]
    Part V2 has no 'VOFF' property"
    "WARNING:  [NET0093]
    No PSpiceTemplate for C1, ignoring "
    C1 is a polarized capacitor
    thanks
  • anandh
    anandh over 14 years ago
    hello sir i try to design counter by using 7493. but i got the following error how to i recover it pls help me
    WARNING(ORNET-1119): No PSpiceTemplate for U1, ignoring
    WARNING(ORNET-1119): No PSpiceTemplate for U2, ignoring
    WARNING(ORNET-1119): No PSpiceTemplate for U3, ignoring
    WARNING(ORNET-1119): No PSpiceTemplate for U4, ignoring
  • Alok Tripathi
    Alok Tripathi over 14 years ago
    You should use 7493 part from ../tools/capture/library/PSpice folder. You can find this part in 7400.olb
