  3. text sizes
  • Views 13360
text sizes
hcowles
hcowles over 17 years ago
Allegro starts out with 16 text sizes in the librarian and Allegro tools, for a new part or a new board database. Over a period of time databases accumulate additional text sizes as designers add new text sizes.
is there any way to purge the additional text sizes that are not being used?
  • KeithP
    KeithP over 17 years ago
    Yes you can,
    Setup -> Design Parameters -> Text -> Setup Text Sizes -> Compact
    KP
  • hcowles
    Thanks Keith
    I just opened a board file, turned everything on/visible and then changed text to size 3
    Changed 8587 items out of 16762 items found.
    after I followed the sequence to compact there were still 18 different text sizes numbered from 2 to 29 with some numbers skipped in between then closing and reopening the text setup resets the numbering from 1-18 when I do a global listing of text all 16790 text blocks are #2 but there are still 18 text sizes in the database is this to be expected
    howard
  • KeithP
    I see a not too dissimilar result, my quantities are somewhat different. This is odd. I can only imagine that there are text features which are not visible but are still contained within the database in an embedded form. I have also done a dbdoctor etc. with no noticeable difference.
    I shall keep looking.
    Keith
