  3. Crosshatch shape problem
  • Replies 7
  • Views 17784
Prasanna
Prasanna over 17 years ago
Hi all,
I am using Orcad PCB editor 16.0   In my board I need to put  hatch plane on top layer connected to GND. I am able to draw hatch shape with proper net name. But, after  I observed that it's overlapping on all the pads. Its not taking pad clearence even i set the constraint manager and global shape parameter. I am getting lot of errors since all the pads are shorted with shape.
and one more thing is that its not getting thermal relief  for related pads.
what could be the wrong in this case?
thanks
prasanna
  • steve
    steve over 15 years ago
    Check that the shape is a dynamic shape and not a static one. If you use Shape - Change shape type, in the options menu make sure the shape type is dynamic copper then select the shape you are having an issue with.
    archive over 15 years ago
    I'm using Allegro v16.3 and ran into the same problem.  It doesn't seem to be a bug, but rather a lack of documentation.  I managed to figure it out for myself:
    1) main menu: Shape (polygon, rectangular, circular)
    2) options panel: select class and subclass (layer), and net name
    3) define boundary of shape; while command is in process, shape appears solid
    4) right-click mouse; from menu, choose Parameters; on Shape fill tab, change "solid" to "Xhatch" and select "apply" and "OK"
    5) right-click mouse and select "Done"
    regards,
    Bob
