  3. Creating Part for Allegro SI
  • Views 14263
wERerABbiT
wERerABbiT over 17 years ago
 Hi All,
 I'm trying to create a 2 pin part that consist of
a) A series resistor and inductor
b) 2 capacitors connected to ground
                   |---Rs---|
pin1-------------|          |------------pin2
          |        |---Ls---|        |
         C1                        C2
      GND                        GND
The part should only consist of 2 pins. (even in the schematics it should be a 2 pin part and does not show the discrete components)
However when the topology is extracted to SigXplorer, it should expand to all the parts shown.
May I know how do I create such a part?
Also since pin1 and pin2 is connected through a resistor, the nets connected to the pins should be an Xnet.
Thanks All
** I tried "Attach Implementation" --> Schematic View   and attached a schematics with the discrete parts and 2 ports but that doesnt work **
  • DavidP
    DavidP over 17 years ago
    Normaly for this you create an Espice model, i will make it like this:
    ("myRC_model"
    ("ESpice"
    ".subckt my_comp 1 2
    R1 1 2 1Meg
    C1 1 0 1.5pF
    L1 1 2 1
    C2 2 0 1.5pF
    .ends my_comp")
    ("PinConnections"
    ("1" "0")
    ("2" "0")
  • wERerABbiT
    Thanks David
    The Espice model works.
    However, with
    ("PinConnections"
      ("1" "0")
      ("2" "0")
    I cant obtain the whole Xnet when net is extracted to SigXplorer
    When I change it to
    ("PinConnections"
      ("1" "2")
      ("2" "1")
    and extract net... I get the whole Xnet topology
    a) Is it wrong to use the pin connections as "1" "2" & "2" "1" ?
    b) How do I ensure that node 0 is connected to GND ( with a 2 pin part) and will simulate correctly ?
