  3. netlist errors
  • Views 14621
netlist errors
JETEE
JETEE over 17 years ago
I have few errors while creating netlist. They are,
#1 Error [ALG0032] Pin Number "0" found on Pin "+" of Package VDC, V1: FULLADD, FULLADD (7.60,1.00). Pin number should be greater than "0"
#2 Error [ALG0031] Pin Number missing from Pin "OUT" of Package DigStim1, DSTM1: FULLADD (1.10,1.80). All pins should be numbered.
#3 Error [ALG0031] Pin Number missing from Pin "OUT" of Package DigStim1, DSTM2: FULLADD (1.00,3.40). All pins should be numbered.
 #4 Error [ALG0031] Pin Number missing from Pin "OUT" of Package DigStim1, DSTM3: FULLADD (1.00,4.00). All pins should be numbered.
Please advice how to fix these errors.
  • Cadpro2K
    Cadpro2K over 17 years ago
    You need to go into the part on the schematic side and correct the pin number issues described. The 1st one is a 'zero' numbered pin. This is easily corrected by changing it to pin1 or whatever.
    The other parts are missing the pin numbers on the schematic parts. Correct them.
    Good day. Mitch
  • JETEE
    JETEE over 16 years ago
     Thanks for the help Mitch.
    I got another question. This one is for a different circuit. And I am looking for a 4 Pole Double Throw Relay and I have found DPDT and DPST relays in PSpice. So if anyone can suggest which library's might have this Relay, please let me know. So far I have found relays under ANL_MISC and MIX_MISC libraries.
