  3. how to view/edit footprint in *.dra?
  • Subscribers 167
  • Views 8731
hankf
hankf over 16 years ago
I exported all the footprints from one reference design to one directory, all the footprints are saved as *.dra and *.psm. Now, I would like to view/edit and add these footprints to one footprint library(*.llb), can someone help me how? (I tried with library Manager but have not figured out a way to view the footprint in *.dra). thanks!
  • Ejlersen
    Ejlersen over 16 years ago
    I think you're confusing Layout and PCB Editor.
    In  OrCAD Layout footprints are saved in libraries called .llb
    In PCB Editor (OrCAD and Allegro) footprints are called Package Symbols and here the following is the case
    • Each package symbol (footprint) consists of 2 files (.dra and .psm) - .dra can be opened and edited. .psm is a compiled version created everytime you save a .dra file..psm is also the file placed on the PCB
    • Since each package symbol is 2 files, you refer to them using the psmpath that consists of one or more directories. These can be setup using Setup->User Preferences.
    Best regards,
    Ole
  • hankf
    Thank you very much, Ole! I can open/view the package symbols in PCB Editor now, not in the Layout.
  • techworks
    techworks over 14 years ago
     since you have done this have you figured out after opening the symbol  .dra file in PCB Editor...(Key word editor) ..How the heck do you make edits...I've been floundering about trying to delete a connector pin.  I can select the pin , move it around  but can't see how to delete it .. Hope you can help.
  • EvanShultz
    EvanShultz over 14 years ago
    Hit the delete icon in the toolbar (or go to Edit > Delete), then click on the pin. Same as deleting an element on a PCB, except there's no option to delete the pin in the RMB menu. Am I missing something?
