  3. Converting HSPICE model to ESPICE model
  • Views 13962
wERerABbiT
wERerABbiT over 16 years ago
Hi All,
I'm trying to manually converting a HSPICE subcircuit to ESPICE so it can be used in Allegro SI. (no i dont have HSPICE license)
The circuit contains a Lossy Transmission Line
.model ms50 u level=3 elev=1 dlev=2 plev=1 nl=1 nlay=2 ht=139.6e-6 wd=164.9e-6  th=16.5e-6 ts=430e-6 kd=3.8
_______________________________________________
level=3     --> Lossy Transmission Line Model
elev=1      --> Electrical Model = Geometry
dlev=2      --> Dielectric Model = Stripline
plev=1      --> Physical Model = Planar
nl=1        --> Number of Conductors = 1
nlay=2      -->
ht=139.6e-6 --> Height of All Conductors = 139.6 micrometer
wd=88.8e-6  --> Width of Each Conductor = 88.8 micrometer
th=16.5e-6  --> Thickness of All Conductors = 16.5 micrometer
ts=430e-6   --> Distance Between Reference Planes (Stripline Only) = 430 micrometer
kd=3.8      --> Dielectric Constant = 3.8
ESPICE uses the Multi-Conductor Transmission Line Model (
Nxxxxxxxx (ni1 ni2 ....nri) (no1 no2 ..... nro)
L=length-in-meters [file=RLGC_input_file_name rlgc_name=data_name_tag
skin_cutoff_freq=fskin dielecloss_cutoff_freq=fdielec]
which requires the RLGC values.
1) How do I obtain the RLGC values from the HSPICE model? (Do these values default to a certain value when not given?)
2) Is there a better way to define the lossy transmission line?
Thanks All
  • redwire
    redwire over 16 years ago
    Take the simple approach and build a transmission line in Allegro with the same parameters.  It's missing the Df values to be a valid model but I would use .015 for a starting point until you know what material was selected.
    Allegro SI will extract a lossy tline with the values in the HSPICE description.
  • wERerABbiT
    It worked!!
    Used sigXplorer, placed a stripline and entered the HSPICE parameters.
    R = 11.43 ohm/M
    L = 380nH/M
    G = 0.0171 mho
    C = 111.2 pF/M
    Thanks Redwire!!
  • wERerABbiT
    Hi All,
    The ESPICE Multi-Conductor Transmission Line Model is
    1) May I know the purpose of "name=data_name_tag" ?
    2) R and G values are frequency dependent. For the RLGC file, how many different frequencies (with corresponding RLGC values) should I include? Also, what should I set for the cutoff frequency?
    Thanks All
