  3. Viewing of board file in 3D image.
  • Replies 15
  • Subscribers 168
  • Views 19008
C Shiva
C Shiva over 16 years ago
 Hello everyone,
 Is there any option to view the board or library files in 3D image at the tool? Our's is v16.0. Or is there any free software availabe? Thanks in advance.
 Shiva.
  • urcuterock
    urcuterock over 16 years ago
    can be seen in Cadophia....export dxf from ur brd and open it with cadophia...
  • Robyd
    Robyd over 16 years ago
    Hi Shiva
    You can extract IDF files which can be seen in mechanical softwares that have the import IDF files.
    IDF are 2 files
    first representing the board outline ,holes,keepouts,components placement.
    the second file contains 3D info about all components (extracted from the placebound subclass + height info )
    There are few softwars that can view/export IDF files
    http://www.oracle.com/technology/products/autovue/index.html
    http://www.capinc.com/pages/Products/circuitworks.cfm
  • Saravana
    Saravana over 16 years ago
    Try this
    http://www.simplifiedsolutionsinc.com/images/Steps_to_create_3D_PCBs_in_ProE.pdf
    Regards
    Saravana
    Sr.PCB Designer
    Force10 Networks
  • C Shiva
     Thanks to all. But i'm not able to download the files from oracle and capinc. And the Pro E is not a free software. Any help. Is there any other free softwares available?
  • Alicia
    Alicia over 16 years ago
    Hi, Try this:
    http://www.oracle.com/webapps/dialogue/dlgpage.jsp?p_ext=Y&p_dlg_id=7163482&src=6674433&Act=44
    It is a 15 days demo of a sort of universal viewer.
    It loads directly your brd file... and you can view it also is as a 3D image up to 16.2 version.
     Bye,
     Alicia
