  3. Highlighting nets from Allegro Constraint Manager
  • Views 15575
Russ Boquette
Russ Boquette over 16 years ago
Is there a way to highlight nets from the Allegro Constraint Manager?
  • Randy R
    Randy R over 16 years ago
    Open CM.
    Go to main window and start highlight command.
    Go to CM, right-click on net, and choose "Select".
  • lcanx2
    lcanx2 over 16 years ago
    In 16.1 you can first enter Constraint Manager,  then enter the highlight application, left click on the networks you are interested in (use the Ctrl key to choose networks that are not grouped together in the spreadsheet), then right click and choose Select.  That is one method.
    Bill
  • Russ Boquette
    That was too easy, I can't believe I did not figure that out for myself. Thank you for the quick response.
