  3. Article Named: Calculating Impedance in Allegro PCB SI Allegro...
  • Subscribers 166
  • Views 14012
Article Named: Calculating Impedance in Allegro PCB SI Allegro PCB SI
John Pasurka
John Pasurka over 16 years ago
I have an out date link to the article named: Calculating Impedance in Allegro PCB SI Allegro PCB SI, that at one time was linked to from the cdnusers site. I tired searching for this article but could not find it. If anyone knows the link to access this article it would be appreciated.Thanks,John
  • Cadpro2K
    Cadpro2K over 16 years ago
    Hi John,
    This is not the exact article, but thought I would pass it along. It might be of use to you.
    http://www.alspcb.com/pdfs/Controlled_Impedance.pdf
  • redwire
    redwire over 16 years ago
     I think you're looking for this: Cadence Stackup Setting for Signal Integrity
  • John Pasurka
    Thank you... I will check out this article...
  • John Pasurka
    You could be right that this is the article I am thinking about. Thank you.
  • lynsey
    lynsey over 10 years ago
    You may like to check part of the book - at http://referencedesigner.com/books/si/impedance_calculator_allegro.php which is very helpful.
