  3. avg power
  • Subscribers 166
  • Views 15451
avg power
JETEE
JETEE over 16 years ago
How can I find average power across any component for a given schematic in ORCAD/Captur CIS?
JetEE
  • redwire
    redwire over 16 years ago
     No simple answer. Got to get the pencil out and do the calculations based on your assumptions.
    Good reading here: http://www.eznec.com/Amateur/RMS_Power.pdf
    I assume you have a basic physics/EE background as well.
  • JETEE
     I have the calculations done on paper but would have still liked to know how to use the software to compute that as well . . .but I did resolve the issue anyhow!
    JETEE
  • MAAC
    MAAC over 16 years ago
    JETEE,
     After runing the ckt. Follow the below steps to obtain the average power from PSPICE A/D window
    Trace-Add Trace-Select Analog operators and Functions(from Function or Macros) and choose AVG() and then choose the W(x) from simulation output variable (where x is the component).
  • redwire
     He says he's in OrCAD not PSPICE.  :)
  • JETEE
     Thanks MAAC...will follow it up.
