  3. Problem loading skill files
  • Replies 13
  • Subscribers 166
  • Views 21780
pakistan
pakistan over 17 years ago
Hi
I am new to allegro and I never use any skill file in it I studied it in the forum and try it to load but I have some problems. I want to use logoMaker when I load it in the pcb editor it shows this message in command window
Command > skill load("logoMaker_public.il")
function logoMaker_start redefined
function logoMaker_mkBitmapDefaults redefined
function logoMaker_needMkbitmap redefined
function logoMaker_potraceDefaults redefined
function logoMaker_check4plugins redefined
function logoMaker_formAction redefined
function logoMaker_validSymbolName redefined
function logoMaker_drawPbm redefined
function logoMaker_setSizeFields redefined
function logoMaker_setDynamicsRotMir redefined
function logoMaker_mkbitmap redefined
function logoMaker_create redefined
function logoMaker_rotate redefined
function logoMaker_mirror redefined
function logoMaker_createSym redefined
function logoMaker_Help redefined
function PtsToUnits redefined
function Lerp redefined
function BezierPt redefined
function BezierToPath redefined
function logoMaker_formOpenFile redefined
function logoMaker_formHeader redefined
function logoMaker_formEnd redefined
function logoMaker_formPopupDefine redefined
function logoMaker_formMessage redefined
function logoMaker_formGroup redefined
function logoMaker_formText redefined
function logoMaker_formButton redefined
function logoMaker_formChecklistItem redefined
function logoMaker_formStrFillin redefined
function logoMaker_formRealFillin redefined
function logoMaker_formIntegerFillin redefined
function logoMaker_formColor redefined
function logoMaker_formPop redefined
function logoMaker_formThumbnail redefined
function logoMaker_formIntSlideBar redefined
function logoMaker_formSetLayerSubColour redefined
function logoMaker_formOptionsString redefined
function logoMaker_formOptionalString redefined
t
i think somthing is happening but I dont recieve any window from which I can read any bitmap file
thanks in advance.
Regads
Tanveer
  • eDave
    eDave over 16 years ago
    OK. You need to closely follow the instructions at the top of the file. You do need the plugins and they need to be installed in the right place identified by the system variables.
    However. I have a new version of this code that uses ImageMagick in place of LFC and is multi-platform. This might help some of you who are struggling to get logoMaker to work. I will upload the code in a separate post.
    Dave
  • eDave
    Dave
