  3. Problem moving symbol - get "Symbol has no pin 1" error
  • Views 1964
mgcorr
mgcorr over 17 years ago
Hi
I am trying to move a pcb footprint symbol for a diode. The symbol has pin labels "C" and "A", instead of "1" and "2", but I wouldn't think that would be a problem. After importing my netlist, I can place the part ok, but I can't move it - it's frozen. When I do try to move it, the log window shows the message: "Symbol "xxx" has no pin 1."
Any ideas?
 thanks
Michael
  • pakistan
    pakistan over 17 years ago
    I dont think pin lables creating any problem.
    Check is there any "fix" property attached to the component? If any unfix it then probably you can move the component.
    Best Regards
    Tanveer
  • KeithP
    KeithP over 17 years ago
    In the OPTIONS tab you have the Point set to “Sym Pin #” and set the “Symbol pin #” to 1. This will select a symbol by its pin designation of 1. Your symbol does not have a pin 1 so you cannot select it. If this is set to A or C, or the Point is set to “Sym Origin” or “Body Center” then you will be able to select the symbol just fine.
    Keith
  • mgcorr
     Keith
    That worked - thank you.
    Michael
