  3. importing FPGA design into Design Entry HDL
  • Views 13100
bdatta
bdatta over 16 years ago
Im trying to take a design from Altera quartus for an FPGA using LVDS differential IO pins.  But when I import the design into Allegro part developer the part that is produced only has single pins for the IO, no differential pairs.  Am I doing something wrong in Quartus or in the Allegro Part developer?
  • redwire
    redwire over 16 years ago
     If I understand your question correctly, the part developer does not keep track of diff pairs -- you do.  You need to apply the property to the net pair and it will forward into Allegro.
