  3. back annotate from allegro(pcb) to orcad(schematic)
  • Views 7758
pakistan
pakistan over 16 years ago
Hi all,
can I back annotate net from allegro(ver16.0) brd file to orcad schematic.
I have a connector in layout which I can rout as "best rout" but it is very difficult and lengthy process to rout in pcb and then assign ports in schematic manually.
Before allegro we use Pcad. In Pcad we can do it by generating netlist from pcb after best rout and then we compare both netlists and after comparing an ECO file generated, by loading this ECO file in schematic, ports automatically placed according to routing in the pcb layout.
is there any way like this in allegro to rout in pcb then load it in schematic which will reflect accurate pcb routing.
Thanks & Regards
Tanveer
  • pakistan
    actually I have allegro ver16.0 and allegro capture cis ver16.0.
    what is the procedure you follow if you have option to rout according to ease of routing. please let me know the simplest method of doing that sort of thing
    Thank & Regards
    Tanveer
  • oldmouldy
    oldmouldy over 16 years ago
    I guess that you mean that connector pins have been swapped inthe PCB to aid routing the PCB? This can be transfered back to the schematic through back annotation. The easiest way is to open Capture, pick the DSN file in the Project Window and then use Tools>Back Annotate, pick PCB Editor tab, specify the netlist directory and BRD file, check Update Schematic and OK to run the Back Annotate. IF you have any reason to believe that the files might not be correctly related, ensure that you have a backup copy of the DSN and BRD files before running Back Annotatation.
  • pakistan
    Hi, Thanks oldmouldy for your prompt reply.I want to confirm one thing when we swap pin in connector as per our routing ease without updating schematic first, we have DRC errors on these pins. Should we ignore them during routing? In my understanding this procedure shold be done after completion of routing, Am I right?
    Thanks & Regards
    Tanveer
  • oldmouldy
    The parts need to be setup to enable pin swapping in the PCB, otherwiae you will be attempting to route the PCB differnetly from the netlist. Use Place>Swap> Components, Functions, Pins as required. Unless you use the Place>Swap functions the loaded netlist will not be changed correctly and the changes will not be back annotated. See Chapter 14 of the Capture USers Guide, cap_ug.pdf in the doc\cap_ug directory within the product installation.
  • pakistan
    Hi oldmouldy,
    Thanks for your guidance. It is working. Now I am able to do back annotation. Thanks again dear, you are a nice person.
    Best Regards
    Tanveer
