  3. How to delete unconnected pins?
  • Views 15159
Prasanna
Prasanna over 16 years ago
The tool I am using is Orcad16.0.  Is there any way to delete the pins of symbol?
*we can modify the footprint( .DRA) file and can update in  .BRD file
But my problem is I am converting a design from PADS to ORcad. In PADS design there are few Relays has got 8 pins. But pin number assigned as 1,2,5,8,9,12,15,16 and other pins(3,4,6,7,10,11,13,14)not placed.
When I imported in Orcad, its getting all 16 pin for that relay and due to appearance of unconnected pins its getting lots of error.
Then I exported design to linrary to get all footprint. I  modified related footprint and uploded, but its reporting error about missed pin because i have removed unconnected pins from that footprint.
Can anybody please suggest me to remove unconnected pins ?
Prasanna
  • Prasanna
    Hi...
    You are right if we are having orcad schematic and netlist file. But I have PADS ( .ASCII)netlist file. I checked that file, it doesn't have any information about unplaced pins. I dont know what is the reason that Orcad taking unconnected pin automatically even that detatils are not in netlist file.
    In PADS they have used only 1,2,5,8,9,12,15,16.  and other pins are not there. But when I took that file in Orcad, automatically its assigning some pads to left out pins (3,4,10,11,13,14).itself.  It should not.
    Prasanna
  • Prasanna
    Hi...
    Prasanna
