  3. How can I properly copy objects with strokes.
  • Subscribers 162
  • Views 13959
blockst
blockst over 17 years ago
I want to configure my copy stroke to work exactly as it does with Mentor Graphics. I mapped copy all to the C shape, however, it then makes me select an object instead of using the ones that are already selected. It then only allows me to select one object instead of multiple ones with the stroke. It then changes the visibility of properties that I want to remain invisible. Is there a different command that I can map to the stroke so this function will work properly?
  • Jerry GenPart
    Jerry GenPart over 17 years ago
    I don't think you can affect a stroke command on multiple objects. It's based on the object that you're mouse hovering over.
