  3. Skill version support
  • Replies 10
  • Subscribers 163
  • Views 17811
purikku22
purikku22 over 17 years ago
good morning. im using allegro pcb design L license. does this version support skill loading?
tnx
good day
eric
  • eDave
    eDave over 17 years ago
    Hi Eric,
    Yes - through your ilinit file.
    Cheers, Dave
  • purikku22
     thanks dave. but i cannot find any allegro.ilinit file, all i have found is example.ilinit located at C:Cadence/Allegro15.7/share/local/pcb/skill. is that the one? i copied the skill programs there but when i  try loading them "command not found" appears in the command line. thanks for the help.
    regards,
    eric
  • Ejlersen
    Ejlersen over 17 years ago
    Skill support in Allegro PCB Design L tiers are limited to load at startup. So you cannot load them while inside a PCB Editor session.
    You can use the attached allegro.ilinit inside your pcbenv directory, make sure to open the file in a text editor and change the first line to a path for your skill files - remember to use forward slashes
    Best regards,
    Ole
    allegro.zip
  • redwire
    redwire over 17 years ago
    Performance L does not have this restriction.
  • Ejlersen
    Yes, you are correct, sorry for not clarifying this good enough.
    This limitation is in OrCAD PCB packages and Allegro PCB Design CIS/HDL L
    - limitation is NOT IN Allegro PCB Performance Option L
    Best regards,
    Ole
