  3. No Connect Pins in CIS
  • Subscribers 166
  • Views 15670
dschaefer
dschaefer over 16 years ago
 Anyone have feedback on best method of handling NC pins?
Some ideas I have are:
1. Leave to schematic designer to enter as a property during schematic entry (least preferred)
2. Build into the schematic symbol - can this be done as a property rather than requiring graphical representation ?
3. Enter NC pins into CIS database and have CIS load the property
  • Khurana
    Khurana over 16 years ago
     Regarding 2, yes, you can set the NC property (don't remember the exact syntax - look in Help) on the symbol.
  • redwire
    redwire over 16 years ago
    I go back and forth on the "preferred" method.  History shows that I prefer attaching the "NC" property to the symbol with the pin numbers.  This is especially useful when you have 10 or more pins. On parts with only 2 or 3 pins I usually just add them as NC1, NC2, NC3...
    Some folks like to "see" the NC pins ... to that I say display the property on the symbol when the property has been added.  The attached image shows a case where the pins were shown to aid the curious.
