  3. copy Paste in text edit
  • Views 16845
pakistan
pakistan over 16 years ago
 Hi all,
I am facing problem in labeling, I have an excel file which have a list of signal, I have to label them on pcb. I know about “read from file” option but is there any way to copy text from excel and paste it in edit>text option.
Thanks & Regards
Tanveer
  • Cadpro2K
    Cadpro2K over 16 years ago
    Cool. Easy.
     Output the excel file in .txt format. Modify the .txt file to only include what text you want.
    In allegro: ADD TEXT - RMB (right mouse button) - 'from text file'
    Pick the text file you want to import, and whalla - it's there.
    Be sure you set the text size you want before you do the final import (Undo works well here)
    Good day.
    Mitch
  • pakistan
    Wow cool
  • Kamran
    Kamran over 16 years ago
    I also have the same problem to label many signals but the way you tell
    is not an easy way to again and again read the text because if we read a singal file, texts can't be seperated like we have to label to signals when they are far apart.
    may you understand my point of view.
    My question is now same, Is there any way to paste text in text editor like we can paste text in Capture CIS.
  • Randy R
    Randy R over 16 years ago
    Don't know if this is what you mean, but you can highlight the text then right-click->copy in Excel.  Then do text->edit in Allegro, then right-click->paste in the command window.
  • pakistan
    HI,
    Yes there is a way to paste in text edit.
    first you have to choose general edit by RMB Application Mode>General Edit then go to Find Menu and Choose Text.
    Now press RMB on text where you want to paste text and choose "Text Edi" a popup window will appear where you can paste text copied from any where.
    Regards
    Tanveer
