  3. How I can use my PCB-Design multiple times on one Board
  • Replies 8
  • Subscribers 168
  • Views 15329
mainframesk
mainframesk over 16 years ago
 my design has a very small outline, therfore i want print it multipe on the Board (20 to 50 times) and seperate the parts after etching. How I can do that with Orcad PCB Desinger?
 I'm Beginner in designing with OrCAD.
 Thanks a lot for helping
 Stefan
  • steve
    steve over 16 years ago
    Hi
    If I understand what you want, then the easiest way is to use edit - copy or file - import - sub drawing. You can copy 1 then 2, then 4 then 8 etc to step and repeat your circuit. If you copy components and routes they may produce DRC's unless you have them all in your netlist. You could also look at a gerber tool or manufacture tool like GC Prevue or Cam 350 which has panelisation functionality.
  • mainframesk
    thanks for answering! Do you have a link with a detailed description or an example of copy and paste Layouts in OrCad PCB Designer?
     Why have such an expensive software no feature for that?
  • steve
    No links, I would suggest just giving it a try, it's quite informative whilst using. As to other options - If it's a design reuse thing then you can try looking at creating a module (see the inbuilt help) You can do this at both schematic and pcb ends. If you really need something more look at upgrading to Allegro Design L 16.2. This has a new feature called create cluster (RMB place replicate create and apply) Part of the placement application mode and is superb. A great addiditon by Cadence. Design Reuse as it should be done based on the imported netlist only.
  • Ejlersen
    Ejlersen over 16 years ago
    It really is easy to use the copy command.
    As Steve mention, if you're inside the PCB select Edit, Copy - use the Find control panel to specify what objects are copied.
    You can also copy across PCB designs. Use File, Export, Subdrawing - again use Find control panel to specify what objects are copied. Now drag a box around the select objects, pick a origin (use RMB; Snap to object) and save of to disk.
    Use file, import subdrawing to insert the "clipboard" drawing.
    Best regards,
    Ole
  • shangwu
    shangwu over 15 years ago
     I tried File --> Export --> Sub-Drawing, but the dynamic filled shapes and refdes do not work.  Any idea?
    Thanks.
